[Qgis-developer] Contributing to qgis using git
Gary Sherman gsherman at geoapt.com
Mon Jan 3 22:09:33 EST 2011
On 1/3/11 5:27 PM, Nathan Woodrow wrote:
> Thanks Gary,
> This maybe be a noobish question but I thought I would ask first before
> doing anything.
> Say I'm working on a new feature/bug/whatever and I have made a branch
> in my git repo to work on it and have pushed the branch to git hub.
>   Wouldn't it be better to make a pull request from the branch rather
> then merging into my master line and making the pull request from there?
Yes.
> My reasons for this are: if I work on a new feature and merge it into my
> master line then make a pull request to qgis/qgis and my new feature,
> for whatever reason, doesn't make it into the main qgis repo, my master
> branch will always have my changes regardless of if the qgis team decide
> that are not needed. Every time I do a pull request for something else
> in the future those changes will be still there and wanting to get
> pulled across.
> My thoughts were to keep the master branch clean, with only the changes
> from the main repo qgis/qgis using git fetch upstream; git merge
> upstream/master [keeping the branches up to date using the same method]
> and then branch and ask for pull request from the branchs into the
> qgis/qgis project.  That way if the feature is broken/not needed I can
> just kill the branch and start over from master.
Make sense.
-gary
> Hopefully that made sense.  What are your thoughts?
> - Nathan
> On Wed, Dec 29, 2010 at 3:24 AM, Gary Sherman <gsherman at geoapt.com
> <mailto:gsherman at geoapt.com>> wrote:
>     On 12/28/10 3:36 AM, Nathan Woodrow wrote:
>         Hi All,
>         I was just reading this:
>         http://spatialgalaxy.net/2010/12/27/contributing-to-qgis-using-git/
>         Is this a better method for submitting patches vs attaching a
>         patch in trac?
>         - NathanW
>     It depends on what you want to do. For a one-off patch there is no
>     reason to use git and clone the repository. If you want to continue
>     to contribute, keep your working copy up to date, and be able to
>     push changes, then using GitHub makes sense.
>     If you are doing QGIS work and wish you had SVN access, then the git
>     route is for you...
>     -gary
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         <mailto:Qgis-developer at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
>     Gary Sherman
>     Chair, QGIS Project Steering Committee
>     -Desktop GIS Book:
>     *http://desktopgisbook.com
>     -Geospatial Consulting & Hosting
>     *http://geoapt.com
>     "We work virtually everywhere"
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Gary Sherman
-Desktop GIS Book:
*http://geoapt.com
