[Qgis-developer] Determine QGIS version from Python
Chris Crook ccrook at linz.govt.nz
Wed Jan 5 14:41:01 EST 2011
Hi All
I'm looking for help on how to find the Qgis version that is running from Python, in order to put version conditional code into a plugin.
I think that generally it is a better idea to test specific capabilities, but in this case I can't find a way to do that either :-(
Thanks for any help
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
