[Qgis-developer] Unknown CRS problem
    Werner Macho
    werner.macho at gmail.com
    Tue Jan 11 03:59:37 EST 2011
Hi!
definitely correct .. speaking of my own experience it's not just
keeping the data without the .prj files ..
I've also seen a lot of companys (including governments) sending shape
files just as the ".shp"
And i always wonder how ArcGIS is the job of correctly open the files ..
but thats another story ..
still hope that raster reprojection on the fly will work soon!
good luck and many thanks to radim for doing that job!!
regards
Werner
Am 11.01.2011 09:19, schrieb Paolo Cavallini:
> Il giorno mar, 11/01/2011 alle 00.43 +0100, Martin Dobias ha scritto:
>> Ideally if all the data from government is in the same CRS, no
>> reprojecting will happen - because the project CRS will be the same as
>> the CRS of individual layers (thus no warning would be issued).
> The problem here is that many organization keep most of their data in
> the same projection, but without a .prj file.
> So if they work without reprojection, everything works smoothly, and
> they do not see anything wrong with that.
> All the best.
