[Qgis-developer] How long is the compiling time for a build all
QGIS?
maaza mekuria
sailmcm at yahoo.com
Wed Jan 12 22:32:16 EST 2011
Thank you for the input Nathan. I was able to get through the issue.
I now have been able to compile QGIS in VC 2008. But the trunk source has errors and it is not building completely.
I am interested right now in building a sample C++ plugin. I am looking for some documentation on how I can compile a plugin that will run in my trunk (Ver. 1.7) installation would be kindly welcome.
Thank you,
Maaza
--- On Wed, 1/12/11, Nathan Woodrow <madmanwoo at gmail.com> wrote:
Subject: Re: [Qgis-developer] How long is the compiling time for a build all QGIS?
To: qgis-developer at lists.osgeo.org
Date: Wednesday, January 12, 2011, 4:28 PM
Yeah I had this issue when trying to build Qgis on windows. I just moved the whole GnuWin32 to C:\GnuWin32 and re ran cmake to point it to the new path.
Uninstalling GnuWin32 and reinstalling into C:\GnuWin32 might be better then just moving the folder.
Hope this helps.
On Thu, Jan 13, 2011 at 7:57 AM, maaza mekuria <sailmcm at yahoo.com> wrote:
I looked at the build order output and found this error and that is where it seems to have gotten stuck,
3>Generating qgssearchstringparser.cpp
3>m4: cannot open `Files\GnuWin32/share/bison': No such file or directory
3>m4: cannot open `C:\Program': No such file or directory
3>m4: cannot open `Files\GnuWin32/share/bison/m4sugar/m4sugar.m4': No such file or directory
I am not sure why it can not find the the files (the space in the file path is causing this problem?), and where it needs to be fixed?
Any ideas?
build all QGIS?
Date: Wednesday, January 12, 2011, 3:39 PM
I am attempting the first compile trial of QGIS from the trunk and I have been waiting for the compilation to end for the last two hours. Is that how long it will take if one builds all? I am using the OSGEO install in Windows XP with Visual C++ Express 9. My computer has 4GB memory and it is a Core2 Duo 8400 3GHz processor.
What am I doing wrong? The place it is waiting at is shown below (from the output of the compiler) and I only see that it is still continuing and I am compiling the release with
debug version.
30>Performing Pre-Link Event...
30>Compiling manifest to resources...
30>Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
30>Copyright (C) Microsoft Corporation. All rights reserved.
30>Linking...
30>Embedding manifest...
30>Build log was saved at "file://c:\SW\myQGIS\src\astyle\astyle.dir\RelWithDebInfo\BuildLog.htm"
30>astyle - 0 error(s), 0 warning(s)
-----Inline Attachment Follows-----
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110112/25f155d7/attachment-0001.html
