[Qgis-developer] Error for use Coordinate Transform
    Luiz Motta
    motta.luiz at gmail.com
    Sun Jan 16 21:36:32 EST 2011
Hi Devs,
I am making the plugin, where i use this method
"core.QgsCoordinateTransform.transform", the QGis showed dialog error.
I tested by Python console and the same error showed.
The script to run on python console:
from qgis import core
mapCanvas = qgis.utils.iface.mapCanvas()
srsCanvas = mapCanvas.mapRenderer().destinationSrs()
srsGoogle = core.QgsCoordinateReferenceSystem(900913,
core.QgsCoordinateReferenceSystem.EpsgCrsId)
pntCenter = mapCanvas.extent().center()
print pntCenter
coodTrans = core.QgsCoordinateTransform(srsCanvas, srsGoogle)
pntCenter = coodTrans.transform(pntCenter,
core.QgsCoordinateTransform.ForwardTransform) # Error showed here!
print pntCenter
Message error:
Title dialog : Exception
Text message:
forward transform(-0.832741, -0.274682)
failed with error: No such file or directory
My enviroment:
Windows XP
Package from OSGEO install.
QGIS trunck r15051
When i continue running the plugin, the next time call this methods the
error does not appear.
I need initialize one library before call the transform's method  ?
Regards,
Luiz Motta
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110117/6351da1b/attachment.html
