[Qgis-developer] Re: Raster providers
G. Allegri
giohappy at gmail.com
Tue Jan 18 03:36:27 EST 2011
> What about an approach where the out-of-bound values are assigned the last
> value only if reprojection is used (and if the layer does not have a null
> value)?
My two cents, from a user perspective.
We're facing this dilemma with Geotools, where reprojected color mapped
rasters (thorugh SLD) result with borders having the lower color from the
SLD rastersymbolizer. This is a big problem for many users, and we have to
reproject the raster before serving it.
It would be very important to be able to manage nodata values for
out-of-border pixels, to be able to manage transparency and avoid those ugly
borders...
giovanni
2011/1/18 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> > Agreed, int to double conversion could be optimal.
> oops, that should be 'Agreed, int to double conversion could be
> problematic'
> Am Dienstag, 18. Januar 2011, um 09.19:23 schrieb Marco Hugentobler:
> > > I thought that if data type of the source is integer the provider
> > > could represent them as floating point. Byte can be represented as
> > > integer. Bad solution however.
> > This would be quite similar to your current approach, except that people
> > will have the appropriate raster appearance if they don't use reproj. And
> > if they do, they have an undesired border, but still the right colors in
> > the raster area.
> > Regards,
> > Marco
> > Am Montag, 17. Januar 2011, um 17.34:22 schrieb Radim Blazek:
> > > On Mon, Jan 17, 2011 at 10:06 AM, Marco Hugentobler
> > > <marco.hugentobler at sourcepole.ch> > Using NaN sounds like a good idea
> > > and Qt has platform independent support for
> > > > it (qIsNan & co.).
> > > > All other solutions I can think of seem to be more complicated (e.g.
> > > > force a transparency value only if raster is reprojected).
> > > >>float + NaN for byte/int?
> > > > This is not clear to me. Could you explain your approach for
> byte/int?
> > > Radim
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110118/d2ceded1/attachment.html
