[Qgis-developer] Plugins repository
Alessandro Pasotti apasotti at gmail.com
Sat Jan 22 18:26:25 EST 2011
2011/1/22 Gary Sherman <gsherman at geoapt.com>
> On 1/22/11 8:57 AM, Alessandro Pasotti wrote:
>> 2011/1/22 Gary Sherman <gsherman at geoapt.com <mailto:gsherman at geoapt.com>>
>>    On 1/22/11 1:25 AM, Alessandro Pasotti wrote:
>>        2011/1/22 Paolo Cavallini <cavallini at faunalia.it
>>        <mailto:cavallini at faunalia.it>
>>        <mailto:cavallini at faunalia.it <mailto:cavallini at faunalia.it>>>
>>            Il giorno ven, 21/01/2011 alle 19.37 +0100, Alessandro
>>        Pasotti ha
>>            scritto:
>>         > The missing piece was the authentication bridge with OSGEO.
>>            AFAIK this is now working. If so, what prevents us from setting
>>            everything in place?
>>            All the best.
>>        I'was able to login with my osgeo credentials but I couldn't
>>        upload a
>>        plugin: it fails with permission denied on the folder where the
>>        plugin
>>        files should reside.
>>        Somebody with root access to the server should fix it.
>>        [Errno 13] Permission denied:
>>        '********************/qgis/static/packages'
>>    The validation of plugin packages doesn't work properly for all
>>    packages. My plugin that uploads and validates find on the "old" repo
>>    (pyqgis.org <http://pyqgis.org>) fails on the new site:
>>    File upload must be a valid QGIS Python plugin compressed archive.
>>    Cannot find __init__.py in the compressed package: this does not
>>    seems a valid plugin (I searched for pluginbuilder/Makefile__init__.py)
>>    Looks like it is munging things together that shouldn't be....
Your plugin loads without errors on my dev environment (I cannot reproduce
the issue).
I will try on the server tomorrow.
In the meantime, I've opened a project on redmine for the django site.
Alessandro Pasotti
w3:   www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110123/d84626e3/attachment-0001.html
