[Qgis-developer] mirror map lugin broken with trunk?
GOO Creations goocreations at gmail.com
Tue Jan 25 14:41:36 EST 2011
Hi Paolo
I had the same problem with all Python plug-ins that used their own
QgsMapCanvas. There were some changes to the map canvas class and the
appropriate SIP files weren't updated. Here is a link to the ticket I've
created, it also contains a patch: https://trac.osgeo.org/qgis/ticket/3420
I think Tim applied the patch in the last revision. Basically only the
following changes:
Add "void paintEvent(QPaintEvent *);" to python->gui->qgsmapcanvas.sip
It fixed things for me, but it would be nice if you could confirm that
it works. Thanks.
Christoph
On 2011/01/25 09:16 PM, Paolo Cavallini wrote:
> Hi all.
> The handy Mirror map plugin seems to be broken with current trunk: only
> a small mirror window is opened, and I cannot display data on it.
> Anyone confirms?
> All the best.
