[Qgis-developer] dxf read
    Werner Macho
    werner.macho at gmail.com
    Wed Jan 26 07:24:23 EST 2011
Hi!
> Yes, we could allow to set a geometry type and skip all features with a
> different geometry type or better return an empty geometry instead - to get the
> feature count right.
> Or we could extent the layers to have three renderers - one for each geometry
> type.  We recently added NoGeometry - so I figure we know where to look now.
> That way we could also get rid of that PostGIS filter trick (ugly because you
> could remove the filtering subset string).
Whatever it is .. if it helps dxf AND PostGIS it sounds great ..
And if it helps to improve dxf im/export you are my hero (which you
definitely are already)!
Werner
