[Qgis-developer] error in georeferencer
Manuel Massing
m.massing at warped-space.de
Sat Jan 29 08:17:54 EST 2011
Hi Paolo,
> > Warning: Object::connect: No such signal
> > QgsGCPListWidget::replaceDataPoint( QgsGeorefDataPoint*, int )
> > in
> > /home/paolo/build/qgis/qgis_unstable/src/plugins/georeferencer/qgsgcplist
> > w idget.cpp:70 All the best.
apart from this warning (which shouldn't have any side effects), I haven't
found anything which explains the "bad_alloc" you are getting. I suspect
it is a build issue, or the exception is thrown from somewhere else (e.g.
the plugin loader).
If you have any new insights into this problem feel free to open a bug report.
cheers,
Manuel
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110129/eab97791/attachment.html
