[Qgis-developer] New Plugin VectorStudio
Pablo Carreira
pablotcarreira at hotmail.com
Wed Jul 6 14:29:12 EDT 2011
> Hi,
> I installed the plugin I tried to play with it but could not do
> anything. Maybe you could describe what it does. If you know how to make
> a screencast, putting this on, e.g., youtube, is probably the most
> efficent way.
> Mayeul
Ok, tanks. I'll elaborate a better documentation. For now, here is a simple explanation:
1) VectorStudio works based is two selections: "Selection A" and "Selection B".
2) Select the features you want and press 1 in the keyboard to set "Selection A", press 2 to set "Selection B".
3) Run the tools you want.
Pablo.
> Le mercredi 06 juillet 2011 à 14:14 -0300, Pablo Carreira a écrit :
> > Hi,
> > I've uploaded a new plugin called VectorStudio, it provides tools for
> > vectors (geometries) transformations in "edit-time".
> > It has an interface that allows the creation of new tools without
> > changing the main code, you can write 'plugins for the plugin'.
> > It's in very early stage and for now is tagged as experimental.
> > I would appreciate comments and suggestions.
> > Regards,
> > Pablo Torres Carreira
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110706/ad014330/attachment-0001.html
