[Qgis-developer] Re: Fwd: [Qgis-user] QgsVectorLayer causes
"Failed to load" error
Tim Sutton
lists at linfiniti.com
Thu Jul 7 03:47:20 EDT 2011
Hi
On Thu, Jul 7, 2011 at 7:55 AM, leonidas <leonidas_liakos at yahoo.gr> wrote:
> I'm trying to run the following example:
> http://desktopgisbook.com/Creating_a_Standalone_GIS_Application_1
> I set *qgis_prefix = "/usr/local"*
> but the script gives me the same error ("Failed to load ") at layer =
> QgsVectorLayer("mydata.shp", "mydata", "ogr")
> My current sub-directories in /usr/local are:
Where did you install QGIS to? If you installed from a package, your
prefix is probably /usr . Look for libqgis_core.so on your system - it
will give you an indication of what your application prefix is. e.g.
locate libqgis_core.so
Regards
> |-bin
> |-etc
> |-games
> |-include
> |-lib
> |---python2.7
> |-----dist-packages
> |-----site-packages
> |---site_ruby
> |-----1.8
> |-------i686-linux
> |-sbin
> |-share
> |---ca-certificates
> |---fonts
> |---man
> |---ppd
> |---sgml
> |-----declaration
> |-----dtd
> |-----entities
> |-----misc
> |-----stylesheet
> |---xml
> |-----declaration
> |-----entities
> |-----misc
> |-----schema
> |-src
> I also set qgis_prefix to */usr/share* and* /usr/lib* but it also failed.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fwd-Qgis-user-QgsVectorLayer-causes-Failed-to-load-error-tp6482726p6557120.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
