[Qgis-developer] qgis mobile configure log
Marco Bernasocchi marco at bernawebdesign.ch
Sun Jul 10 18:30:11 EDT 2011
Anybody sees anything familiar here? (the QT_QTUITOOLS_INCLUDE_DIR
problem is due to necessitas not having QTUITOOLS yet), what about the
others like the openpty one (has o do with CHECK_FUNCTION_EXISTS(openpty
NEED_LIBUTIL) )?
any hint is welcome
ciao Marco
-- SWIG is not found
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
dpkg-architecture: warning: Unknown gcc system type
arm-linux-androideabi, falling back to default (native compilation)
-- Check for working C compiler:
/opt/android-9-toolchain/bin/arm-linux-androideabi-gcc
/opt/android-9-toolchain/bin/arm-linux-androideabi-gcc -- works
-- Detecting C compiler ABI info
CMake Error: Could not COPY_FILE.
   OutputFile: ''
     copyFile:
'/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_C.bin'
Unable to find executable for try_compile: tried
"/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/cmTryCompileExec" and
"/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec"
and
"/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/Development/cmTryCompileExec".
-- Detecting C compiler ABI info - done
CMake Error at
/usr/share/cmake-2.8/Modules/CMakeDetermineCompilerABI.cmake:40 (FILE):
   file STRINGS file
   "/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_C.bin"
   cannot be read.
Call Stack (most recent call first):
   /usr/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:71
(CMAKE_DETERMINE_COMPILER_ABI)
   CMakeLists.txt:7 (PROJECT)
-- Check for working CXX compiler:
/opt/android-9-toolchain/bin/arm-linux-androideabi-g++
/opt/android-9-toolchain/bin/arm-linux-androideabi-g++ -- works
-- Detecting CXX compiler ABI info
   OutputFile: ''
     copyFile:
'/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_CXX.bin'
and
-- Detecting CXX compiler ABI info - done
CMake Error at
   file STRINGS file
   "/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_CXX.bin"
   cannot be read.
   /usr/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake:64
-- Quantum GIS version: 1.8.0 Trunk (10800)
-- Looking for openpty
-- Looking for openpty - not found
CMake Error at CMakeLists.txt:140 (MESSAGE):
   openpty not found!
-- Found Proj: /home/marco/apps/qgis-mobile/lib/libproj.so
-- Found Expat: /home/marco/apps/qgis-mobile/lib/libexpat.so
-- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
-- Found GEOS: /home/marco/apps/qgis-mobile/lib/libgeos_c.so
-- Found GDAL: /home/marco/apps/qgis-mobile/lib/libgdal.so
-- Found Qwt: /home/marco/apps/qgis-mobile/lib/libqwt.so
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt-Version 4.8.0 (using
/opt/necessitas/Android/Qt/4762/armeabi/bin/qmake)
-- Pedantic compiler settings enabled
-- Debug output enabled
-- txt2tags not found - disabled
CMake Error: The following variables are used in this project, but they
are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the
CMake files:
QT_QTUITOOLS_INCLUDE_DIR (ADVANCED)
    used as include directory in directory /home/marco/dev/qgis/src/gui
    used as include directory in directory /home/marco/dev/qgis/src/app
-- Configuring incomplete, errors occurred!
