[Qgis-developer] QGIS-MapServer 1.7 GetFeatureInfo problem
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jul 11 11:53:06 EDT 2011
Hi Pedro
Could you provide a sample project and dataset for us to test?
> In addition, this same configuration worked without problems before
> upgrading to version 1.7.
Possible is also a library conflict if you have several qgis libs on your
system.
Regards,
Marco
Am Montag, 11. Juli 2011, 17.44:39 schrieb Pedro Venâncio:
> Hello Andreas,
> Yes, I think this aspect is not the problem, everything is in EPSG:20790
> (QGIS project, all layers and the project - and wms layers - as client).
> Thanks,
> Pedro
> ----- Original Message -----
> From: Andreas Neumann
> Hi Pedro,
> Is the CRS (projection, coordinate reference system) set up correctly in
> the WMS and in the WMS client? Is the QGIS project set up correctly with
> the CRS?
> Andreas
> On Mon, 11 Jul 2011 07:19:49 -0700 (PDT), Pedro Venâncio wrote:
> > Hello everyone,
> > I have a problem in QGIS-MapServer 1.7. The result of Identify is
> > blank on QGIS 1.7.
> > I found this problem on a clean Ubuntu install of QGIS and
> > QGIS-MapServer 1.7. Since I had another machine with QGIS and
> > QGIS-MapServer 1.6 running smoothly, I did the upgrade to 1.7 on this
> > machine (also Ubuntu) and the same application crashed the Identify
> > feature after the upgrade.
> > The GetCapabilities continues to show the layers as identifiable
> > (queryable = "1"), however QGIS displays the results in white (see
> > picture). This happens with both point, polyline and polygon features.
> > Can anyone confirm this?
> > Thank you!
> > Pedro Venâncio
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
