[Qgis-developer] Python QgsVectorLayer.commitChanges() problem
Martin Dobias
wonder.sk at gmail.com
Thu Jul 28 07:39:39 EDT 2011
Hi Stefan
On Thu, Jul 28, 2011 at 10:45 AM, Stefan Ziegler <st.ziegler at gmx.net> wrote:
> Hi
> I'm trying to add some features with python to an existing postgis layer:
> tsplayer.startEditing()
> tspprovider.addFeatures(features)
> committed = tsplayer.commitChanges()
> The strange thing is that "committed" is "True" even if the features were not added (because of violating a unique constraint) and dialog popped up:
> ERROR: duplicate key value violates unique constraint "tsp_lv03_nummer_key"
> Should "committed" not be "False" in this case?
In your code you are actually mixing two approaches: one possibility
is to use directly data provider to store changes (they are
immediately written). Or you can use vector layer's editing buffer:
call startEditing(), call some methods that modify the layer and
finally call either commitChanges() or rollback(). Until you commit
the changes, they are only in memory. In commitChanges() they are
written to the data store using provider's methods.
Getting back to your code: first you start editing, then directly
write features to providers (that fails) and finally commitChanges
from layer's edit buffer (which is empty). That's why commit returns
True - because it did nothing.
What you probably want to do:
- in case it is an interactive tool you should use the vector layer's
editing buffer (i.e. call QgsVectorLayer's editing methods). Also you
might make your tool available only when the layer is in editing mode
and leave the decision when to start editing / commit / rollback up to
user - the user then may use also undo/redo functionality.
- if you are working on a data processing tool you probably want to
store the features directly without messing with the layer editing
buffer - then you are better off with using vector data provider.
Regards
Martin
