[Qgis-developer] Composer template: autoUpdate field for ComposerLegend tags
Benoit benoit-3 at bc-consult.com
Thu Jul 28 07:12:16 EDT 2011
Hi Devs,
When Composer loads a template (*.qpt) file it does not honour the
"autoUpdate" flag of the ComposerLegend Model tag.
The autoUpdate is always activated, even when set to 0. The user has
then to redo all the legends present in the template, defeating the
usefulness of having a template at the first place.
But, from inside a Composer tag in the QGIS .qgs file the autoUpdate
value is honoured by the Composer.
Is this behaviour to be expected or is it a bug?
Keep on the good work.
Benoit
