[Qgis-developer] QGIS Plugin - Ovals
Alex Mandel tech_dev at wildintellect.com
Fri Jun 3 14:05:41 EDT 2011
I haven't looked at the Rectangles plugin (yet) but if it does 99% of
the work and you just need to change the formula to make ovals instead
that could be a project that only take a few hours.
Thanks for putting up the suggestion, maybe someone will get to it, but
as Paolo said if you really want to make sure a couple of hundred Euros
would probably be all it takes.
Thanks,
Alex
On 06/03/2011 03:12 AM, uk52rob wrote:
> Hi Giovanni,
> Thank you for your response.
> Yes I have indeed thought about going down the line of sponsorship or sites like 'getafreelancer.com', but I use this for local community based projects, and therefore we hardly have much money as it is.
> I guess if I had the money I would be on ArcGIS as this probably has a tool to do the job along with increased functionality, but unfortunately this is not the case. Besides, I get on well with QGIS and would prefer to stick with it.
> I appreciate everyone has to work for a living and not all developers want to just give away their life's work for free, but if anyone has looked into this before as a test project, or part of another project, then I would be grateful to hear from them.
> If funding were to be available for any development work, are there any systems in place to manage it, such as GAF, as referred to above?
> Cheers,
> Rob
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: 03 June 2011 10:52
> To: uk52rob
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] QGIS Plugin - Ovals
> Hi,
>> I am not a python developer myself, so I am not used to the language.
>> However, if anyone is able to come up with a ‘simple’ (dare I say it)
>> plugin, or has created one before and it has not yet reached a repo, I
>> would be very grateful to hear from you.
> have you considered sponsoring the development of such tool?
> cheers
> -- Giovanni --
> Qgis-developer mailing list
