[Qgis-developer] QGIS Plugin - Ovals
Chris Crook ccrook at linz.govt.nz
Fri Jun 3 14:10:17 EDT 2011
I have published a plugin called vectorfieldrenderer which plots arrows with orientation and scale based field values.  I wrote this for plotting deformation (eg ground moment as a result of an earthquake).  I've been thinking about adding ellipses to it for a while (to represent the measurement errors of the deformation) - and will probably be doing this in the next month or so.  However that may not be quite what you want (either the feature or the time frame!).  One feature of the plugin is that there is a toolbar to allow the user to rescale the arrows, something that is very useful when looking at deformation.
Pity I haven't put the ellipses in already!
Cheers
Chris
________________________________________
Sent: 03 June 2011 21:46
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] QGIS Plugin - Ovals
Dear QGIS Developers,
I have long hoped for a plugin to create ovals based on a point layer. It would ideally have the ability to select orientation in degrees, width and length (with values contained in fields also available).
I notice that Pavol Kapusta created an excellent plugin called ‘Rectangles’ in the contributed repo to do exactly what it describes, but has anyone tried ovals?
I am not a python developer myself, so I am not used to the language. However, if anyone is able to come up with a ‘simple’ (dare I say it) plugin, or has created one before and it has not yet reached a repo, I would be very grateful to hear from you.
Many thanks,
Rob
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
