[Qgis-developer] Fwd: SAGA Interface for QGIS - Weekly report
Nathan Woodrow
madmanwoo at gmail.com
Sat Jun 4 21:06:04 EDT 2011
Looking good. My hope onces this is all done is to be able to rewrite all
the tools in fTools to use the framework. That way eventually everything
can be linked together and called in the same way.
- Nathan
On Sun, Jun 5, 2011 at 12:46 AM, Camilo Polymeris <cpolymeris at gmail.com>wrote:
> Hello,
> This week, I coded a GUI list of modules, sorted by tag (which in the
> case of SAGA are determined programmatically), plus the basics of a
> 'run module' dialog. I have started working on the parameter passing
> aspect of the framework.
> I also set out to handle class generation for the GUI & installation
> of python files from cmake. Being inexperienced in cmake, this wil
> require further study & work.
> Next week I intend to (as per the timeline), add GUI elements for the
> simplest cases of parameters and get the build system working.
> A screenshot, links & prior reports are available through [2]
> Regards,
> Camilo
> > [1] https://github.com/polymeris/qgis/wiki/QGIS-Processing-Framework
> > [2] https://github.com/polymeris/qgis/wiki/Reports
> > [3] https://github.com/polymeris/qgis
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110605/cd41c591/attachment.html
