[Qgis-developer] Re: dealing with "long" primary keys
Mayeul Kauffmann mayeul.kauffmann at free.fr
Sun Jun 5 11:46:35 EDT 2011
I suggest you try osm2postgresql, which converts bigint into int4 to be
compatible with QGIS and works fine so far.
To simplify rendering with QGIS, the osm2postgresql script sets up a
PostgreSQL database, imports OSM data into it and process those data
(including multi-polygons with holes).
However, I've seen on the OSM dev list that some threshold for the
number of nodes will be reached soon and this might become an issue; if
so, I will adapt the script to have a primary key as only nodes with
tags are needed for rendering (in the structure created
byosm2postgresql, there is a table called nodes_with_tags, aimed at
this).
See:
http://wiki.openstreetmap.org/wiki/Osm2postgresql
Hope this helps,
Mayeul
Le dimanche 05 juin 2011 à 03:02 -0700, wambacher a écrit :
> there are a lot of openstreetmap-databases in the world and all of
> them
> can't be used by qgis.
> Regards
> walter
