[Qgis-developer] Qt build for QGIS source
Mars Sjoden
aurorageomatics at gmail.com
Sun Jun 5 14:50:05 EDT 2011
Yes of course William, a very incredibly helpful resource.
I likely am unable to follow instructions correctly, as I am finding (and
remember in my case) there were (are) special steps that I need to take to
build all the pre-req's... Have you ever tried building with two kids
hanging off your arms ^_^ ha ha!
There maybe something I am doing that is causing all our Intel Core 2 Duo's
to cause troubles with QGIS.
for instance:
ld: file not found: QtSvg.framework/Versions/4/QtSvg for architecture x86_64
collect2: ld returned 1 exit status
make[1]: *** [plugins/designer/libqwt_designer_plugin.dylib] Error 1
make: *** [sub-designer-make_default] Error 2
Are these errors normal when making of QWT?
QtSvg for 64bit is missing, so this would suggest that I may have downloaded
the wrong Qt libraries for SnowLeopard?
Perhaps there is no 64bit QtSvg available?
I downloaded the:
Cocoa: Mac binary package for Mac OS X 10.5 - 10.6 (32-bit and 64-bit)
http://qt.nokia.com/downloads/qt-for-open-source-cpp-development-on-mac-os-x
Thanks for the help, these issues so incredibly trivial for you I
understand.
Mars
On Sat, Jun 4, 2011 at 5:00 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> It's all in the INSTALL document in the QGIS source.
> On Jun 4, 2011, at 5:38 PM, Mars Sjoden wrote:
> > Thanks,
> > Tried the SDK download, but throws some errors when building some of the
> dependancies (pyqt I think).
> > Simply installing the libs seems to work so far, …must install to allow
> for dynamic libs?
> > I need to remember to write down this process for myself!
> > Sent from the MarsPhone
> > On 2011-06-04, at 11:07 AM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> >> Don't compile Qt from source, just download the framework installer.
> They also have debug libs as a separate download (it adds to the
> frameworks). For most purposes the "Qt Libraries" downloads are enough, but
> if you need the dev tools, like Qt Designer and the Qt IDE you need the
> larger Qt SDK.
> >> Looks like they changed their download page layout a bit - the
> SDK/Library section used to be side by side, now they're sequential and you
> need to scroll down to find the Library links.
> >> On Jun 4, 2011, at 12:43 PM, Mars Sjoden wrote:
> >>> Hello,
> >>> I am on my wife's computer (Snow Leopard) and am trying to remember if
> I need to build Qt libraries as a static or dynamic library?
> >>> I seem to remember dynamic is preferred for dependancies but also seem
> to remember that the auto-download/build installer for Qt for Mac builds the
> libraries as static?
> >>> What is the smoothest download for Qt (and debugging) that I should be
> using for Mac?
> >>> Thanks!
> >>> a non-developer hack.
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >> http://www.kyngchaos.com/
> >> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not deign
> to possess - money to purchase the effeminate pleasures of weaklings. And
> yet withal bound down by silly customs that make them slaves to their
> unhappy lot while firm in the belief that they be the lords of creation
> enjoying the only real pleasures of existence....
> >> - the wisdom of Tarzan
> All generalizations are dangerous, even this one.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110605/a2cb2434/attachment.html
