[Qgis-developer] Qt build for QGIS source
Mars Sjoden
aurorageomatics at gmail.com
Sun Jun 5 16:22:24 EDT 2011
Cool! did not know that!
Yah, both arch's x86_64 and i386 installed as universal.
I'll keep grinding away at it.
I better keep notes this time!
Thanks
On Sun, Jun 5, 2011 at 12:31 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> Qt Cocoa should have 64bit for all the Qt frameworks. You can check a
> framework archs with:
> file /Library/Frameworks/QtSvg.framework/QtSvg
> I don't know why it's failing on qwt designer. It's not needed by QGIS
> really. Try disabling it in the qwtconfig.pri - comment out the line to add
> it to the config.
> On Jun 5, 2011, at 1:50 PM, Mars Sjoden wrote:
> > Yes of course William, a very incredibly helpful resource.
> > I likely am unable to follow instructions correctly, as I am finding (and
> remember in my case) there were (are) special steps that I need to take to
> build all the pre-req's... Have you ever tried building with two kids
> hanging off your arms ^_^ ha ha!
> > There maybe something I am doing that is causing all our Intel Core 2
> Duo's to cause troubles with QGIS.
> > for instance:
> > ld: file not found: QtSvg.framework/Versions/4/QtSvg for architecture
> x86_64
> > collect2: ld returned 1 exit status
> > make[1]: *** [plugins/designer/libqwt_designer_plugin.dylib] Error 1
> > make: *** [sub-designer-make_default] Error 2
> > Are these errors normal when making of QWT?
> > QtSvg for 64bit is missing, so this would suggest that I may have
> downloaded the wrong Qt libraries for SnowLeopard?
> > Perhaps there is no 64bit QtSvg available?
> > I downloaded the:
> > Cocoa: Mac binary package for Mac OS X 10.5 - 10.6 (32-bit and 64-bit)
> http://qt.nokia.com/downloads/qt-for-open-source-cpp-development-on-mac-os-x
> > Thanks for the help, these issues so incredibly trivial for you I
> understand.
> > Mars
> > On Sat, Jun 4, 2011 at 5:00 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > It's all in the INSTALL document in the QGIS source.
> > On Jun 4, 2011, at 5:38 PM, Mars Sjoden wrote:
> > > Thanks,
> > > Tried the SDK download, but throws some errors when building some of
> the dependancies (pyqt I think).
> > > Simply installing the libs seems to work so far, …must install to allow
> for dynamic libs?
> > > I need to remember to write down this process for myself!
> > > Sent from the MarsPhone
> > > On 2011-06-04, at 11:07 AM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > >> Don't compile Qt from source, just download the framework installer.
> They also have debug libs as a separate download (it adds to the
> frameworks). For most purposes the "Qt Libraries" downloads are enough, but
> if you need the dev tools, like Qt Designer and the Qt IDE you need the
> larger Qt SDK.
> > >> Looks like they changed their download page layout a bit - the
> SDK/Library section used to be side by side, now they're sequential and you
> need to scroll down to find the Library links.
> > >> On Jun 4, 2011, at 12:43 PM, Mars Sjoden wrote:
> > >>> Hello,
> > >>> I am on my wife's computer (Snow Leopard) and am trying to remember
> if I need to build Qt libraries as a static or dynamic library?
> > >>> I seem to remember dynamic is preferred for dependancies but also
> seem to remember that the auto-download/build installer for Qt for Mac
> builds the libraries as static?
> > >>> What is the smoothest download for Qt (and debugging) that I should
> be using for Mac?
> > >>> Thanks!
> > >>> a non-developer hack.
> > >>> _______________________________________________
> > >>> Qgis-developer mailing list
> > >>> Qgis-developer at lists.osgeo.org
> > >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > >> http://www.kyngchaos.com/
> > >> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not deign
> to possess - money to purchase the effeminate pleasures of weaklings. And
> yet withal bound down by silly customs that make them slaves to their
> unhappy lot while firm in the belief that they be the lords of creation
> enjoying the only real pleasures of existence....
> > >> - the wisdom of Tarzan
> > All generalizations are dangerous, even this one.
> "The beast is actively interested only in now, and, as it is always now and
> always shall be, there is an eternity of time for the accomplishment of
> objects."
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110605/2439d3f8/attachment.html
