[Qgis-developer] Re: Call for packaging: QGIS 1.7.0 'Wroclaw'
Charlie Sharpsteen chuck at sharpsteen.net
Tue Jun 7 04:19:24 EDT 2011
On Tue, Jun 7, 2011 at 12:49 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Jun 6, 2011 at 9:42 PM, David Spencer
> <baildon.research at googlemail.com> wrote:
> >> Source tarballs can be obtained from here:
> >> http://qgis.org/downloads/qgis-1.7.0.tar.gz
> > The top level directory in the tarball is qgis-Quantum-GIS-dfd6ece/,
> > not qgis-1.7.0/.  Is that intentional?
> Thats the way gitbub generates the tarball. The hash at the end is the
> exact revision for the release tag. Does it cause a problem for you
> packaging wise? I guess its not so user friendly, so I could unpack it
> rename it and repack it if you think it will be better.
> Regards
> Tim
No need to repack, just use git-archive to export a snapshot:
    # Sync with QGIS repo and pull down tags
    git fetch qgis-upstream
    git archive --format=tar --prefix=qgis-1.7.0/ final-1_7_0 | gzip >
qgis-1.7.0.tar.gz
-Charlie
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110607/d2cbf9bc/attachment.html
