[Qgis-developer] Install Globe on ubuntu!
Marco Bernasocchi marco at bernawebdesign.ch
Wed Jun 8 05:10:43 EDT 2011
Hi Fred, sorry I was busy, did you meanwhile manage to compile it?
ciao Marco
On 05/29/2011 11:06 PM, Fred ETHEVE wrote:
> Salut, Marco,
> Thank you,
> So i've made « make VERBOSE=1"
> And there is the end of the verbose (you want the beginning?), with
> error :
> [ 70%] Building CXX object
> src/providers/grass/CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o
> cd /home/fred/globe/qgis/build/src/providers/grass && /usr/bin/c++
> -Dgrassprovider_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB
> -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
> -DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -DQT_DEBUG -g -fPIC
> -I/usr/include/qt4 -I/usr/include/qt4/QtSvg
> -I/usr/include/qt4/QtWebKit -I/usr/include/qt4/QtGui
> -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtSql
> -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtCore
> -I/home/fred/globe/qgis/build
> -I/home/fred/globe/qgis/src/providers/grass/../../core
> -I/home/fred/globe/qgis/src/providers/grass/../../core/raster
> -I/usr/lib/grass64/include -I/usr/include/gdal   -Wall -Wno-long-long
> -Wformat-security -Wno-strict-aliasing -DCORE_EXPORT= -DGUI_EXPORT=
> -DPYTHON_EXPORT= -DANALYSIS_EXPORT=
> -DGRASS_BASE=\"/usr/lib/grass64/lib\" -DGRASS_EXPORT= -o
> CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o -c
> /home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp
> /home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp: In
> member function 'virtual QVector<QgsDataItem*>
> QgsGrassMapsetItem::createChildren()':
> /home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp:2447:79: error:
> call of overloaded 'QString(int)' is ambiguous
> /usr/include/qt4/QtCore/qstring.h:428:43: note: candidates are:
> QString::QString(const QByteArray&)
> /usr/include/qt4/QtCore/qstring.h:426:43: note:
> QString::QString(const char*)
> /usr/include/qt4/QtCore/qstring.h:728:8: note:
> QString::QString(const QString&)
> /usr/include/qt4/QtCore/qstring.h:106:5: note:
> QString::QString(QChar)
> /usr/include/qt4/QtCore/qstring.h:105:14: note:
> QString::QString(const QChar*)
> make[2]: ***
> [src/providers/grass/CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o]
> Erreur 1
> make[2]: quittant le répertoire « /home/fred/globe/qgis/build »
> make[1]: *** [src/providers/grass/CMakeFiles/grassprovider.dir/all]
> Erreur 2
> make[1]: quittant le répertoire « /home/fred/globe/qgis/build »
> make: *** [all] Erreur 2
> fred at HP:~/globe/qgis/build$
> cheers
> *De :*Marco Bernasocchi [mailto:marco at bernawebdesign.ch]
> *Envoyé :* dimanche 29 mai 2011 20:57
> *À :* Fred ETHEVE
> *Cc :* qgis-developer at lists.osgeo.org
> *Objet :* Re: [Qgis-developer] Install Globe on ubuntu!
> Salut Fred,
> The report you give is not super verbose. The error probably happened
> earlyer, scroll up in the terminal and look for the error. Furthermore
> try to re launch the make step:
> cd builDir
> make ..
> Hope it helps
> Marco
> (sent from my mobile)
> On 29 May 2011 19:53, "Fred ETHEVE" <fred.etheve at wanadoo.fr
> <mailto:fred.etheve at wanadoo.fr>> wrote:
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110608/2f6d6e68/attachment-0001.html
