[Qgis-developer] Testing and releases
Mars Sjoden
aurorageomatics at gmail.com
Wed Jun 8 14:48:55 EDT 2011
I would be interested in participating as "dumb user",
The 'black box' sounds interesting and a way to organize dumb users for
debugging/edu/user docs/ergonomics
mars
On Wed, Jun 8, 2011 at 11:13 AM, MALIK Julien <julien.malik at c-s.fr> wrote:
> Hello,
> Do you know about Sikuli ?
> http://sikuli.org/
> I never tested it, but it seems very nice for the "black box" testing, and
> can probably handle the automatic screenshot generation.
> Cheers,
> Julien
> Quoting Andrew Chapman <andrew.chapman at donkagen.co.uk>:
> I think that there are (at least) two different types of testing that are
>> valuable for a project like QGIS and both play important roles. Different
>> people use different names, but here's my version...
>> 1) White box: This is very much in the hands of the developer and is aimed
>> at proving the functionality of their code - stop the bug before it gets
>> out
>> of your own hands. This type of testing knows how the code should work and
>> typically, among other things, explores the boundary conditions.
>> 2) Black box: This has no special knowledge of how the internals works and
>> tests as a dumb user... that can be relied on to provide the same test
>> coverage every time. One obvious use of this is for regressions testing of
>> the finished build, but I would suggest that with minor enhancements it
>> could be used to help ease some of the user documentation tasks.
>> QGIS supports multiple languages and operating systems, is released
>> regularly but, consequently, it is hard to produce user manuals and
>> tutorials with the most appropriate screen shots, etc.
>> If a "black box" type of test harness were developed that could be
>> "trained"
>> (e.g. recording keystrokes and mouse commands with a way to edit them)
>> plus
>> the ability to capture images of screen objects (windows, dialogs,
>> buttons,
>> icons) and save them to named files, this would present further
>> opportunities. The same test (script?) could be run on builds for
>> different
>> operating systems, languages and versions. A standard set of build
>> specific
>> images would be generated and, assuming standard file names and locations,
>> could automatically be imported into the various user documents. There
>> would
>> still need to be some manual text editing, but the labour intensive
>> screenshot processing would be removed.
>> This must be a common requirement across projects, has anyone come across
>> any tools that already exist?
>> Andrew Chapman
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> This message was sent using IMP, the Internet Messaging Program.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110608/5683997f/attachment.html
