[Qgis-developer] Query Set using SetSubstring does not return
record - resolved but with a question
maaza mekuria
sailmcm at yahoo.com
Wed Jun 8 19:49:51 EDT 2011
Let me lay bare my hearts desire, is it alright to have a method that updates the selection set using the setSubString query? What is the reason that such a powerful way to query the data does not also have a means to update the selection set?
I know I am pushing my luck or my providence. But God is generous to the rich as well as to the poor and I am told to ask always and I am sure there will be answer soon. Or am I talking only to myself here?
Maaza
--- On Wed, 6/8/11, maaza mekuria <sailmcm at yahoo.com> wrote:
> From: maaza mekuria <sailmcm at yahoo.com>
> Subject: Re: [Qgis-developer] Query Set using SetSubstring does not return record
> To: "QGIS Developer" <qgis-developer at lists.osgeo.org>
> Date: Wednesday, June 8, 2011, 5:43 PM
> I figured it out. I was assuming that
> the setSubsetString would do the querying and update the
> selection set, but I gather now after a few hours of
> hardwork that is not its purpose, it just limits the
> accessible features with out changing the selection set.
> How can I help update the documentation to reflect what the
> methods are meant to do?
> Thank you,
> Maaza
> > Subject: [Qgis-developer] Query Set using SetSubstring
> > Date: Wednesday, June 8, 2011, 2:25 PM
> > I have a subsetstring query applied in code to the
> layer
> > data. Yet I find that it does not return any records
> that it
> > should have
> > located.
> > The code is pasted below, the setSubsetString passes
> and
> > yet the selected feature count is 0. What am I
> missing
> > here?
> > //Query the edge table edge
> field
> > to find the two vertices
> > strQryEdge = "EDGEID=" +
> > fld0.toString() + "";
> > if
> > (inEdgeVectorProvider->supportsSubsetString())
> blnQryCur=inEdgeVectorLayer->setSubsetString(strQryEdge);
> > if (blnQryCur)
> > lstEdgeFeats =
> > inEdgeVectorLayer->selectedFeatures();
> > txtStream <<
> > Recount - "<<lstEdgeFeats.count()<<endl;
> > } // if network source
> query
> > returns edge result
> > } // if edge provider
> supports
> > query subst
> > Thank you,
> > Maaza
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
