[Qgis-developer] Query Set using SetSubstring does not return
record - resolved but with a question
Anita Graser
anitagraser at gmx.at
Thu Jun 9 02:51:00 EDT 2011
Hi Maaza,
On Thu, Jun 9, 2011 at 3:10 AM, maaza mekuria <sailmcm at yahoo.com> wrote:
> I have learned from you how I can select all the features in a layer
> through code using extents and attribute lists. What I would like is to be
> able to use a simple command that says layer->selectall() or something like
> that
Feel free to add this feature request to the bug tracker or to even write
the patch to add this function to the layer class.
is it alright to have a method that updates the selection set using the
> setSubString query?
Why not?
> What is the reason that such a powerful way to query the data does not also
> have a means to update the selection set?
Imho, the query string has nothing to do with the selection set. If you
first set the query string, you can then select all features left in the
layer.
Best wishes,
Anita
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110609/26603799/attachment.html
