[Qgis-developer] Ellipse renderer
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Jun 14 11:50:12 EDT 2011
Sorry, my git description does not work. It works with cloning my repository
and checking out the branch (though there must be some magic to add the branch
to a cloned main repository).
git clone git://github.com/mhugent/Quantum-GIS.git
cd Quantum-GIS
git checkout --track origin/data_defined_symbollayer
Marco
Am Dienstag, 14. Juni 2011, 15.48:29 schrieb Marco Hugentobler:
> Hi QGIS devs
> Recently, I was writing a symbollayer to render ellipse shapes (and also
> rectangles, triangles, crosses by specifying width and height). Moreover,
> the symbol layer allows to set all parameters (width, height, colors,
> rotation, outline with) from data fields, in mm or map units.
> The code is contained in my github clone int the branch
> 'data_defined_symbollayer'. To give it a try, you can do the following:
> git add remote add mhugent git://github.com/mhugent/Quantum-GIS.git
> git checkout --track mhugent/data_defined_symbollayer
> The reason it's in a branch is that data defined rendering in symbol layers
> needed some API changes. They are quite small:
> - A pointer to the rendered QgsFeature* has been added to
> QgsSymbolV2RenderContext (such that the symbollayer has the possibility to
> check the data defined attribute values)
> - A symbollayer has the possibility to specify which attribute fields it
> needs for rendering (by default, QgsSymbolLayerV2::usedAttributes returns
> an empty set).
> - The symbollayer widgets receive a pointer to their vector layer. Normal
> symbol layer widgets don't use it, the widgets of data defined symbol
> layers get the available fields through that pointer.
> At first, I tried to achieve the data defined layer without API change by
> creating a new subclass of QgsFeatureRendererV2 (as discussed with Martin
> in Lisbon. However, it turned out this approach would need a lot of
> duplication to provide graduated / unique / rule based classification and
> to provide a seamless integration with the existing symbology(ng).
> What do you think?
> Regards,
> Marco
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
