[Qgis-developer] Annoying bug found in QGIS 1.7 (not present
in 1.6)
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Jun 16 04:58:20 EDT 2011
Hi, did you filed a ticket?
cheers
-- Giovanni --
On Wed, 2011-06-15 at 14:18 +0200, luca_manganelli at comune.trento.it
wrote:
> Hi,
> I wrote a PYTHON plugin that does a simple feature select on a
> QgsVectorLayer:
> pnt = <coordinates of mouse click on map >
> myLayer= <QgsVectorLayer Object>
> tolerance = 1
> rectangle = QgsRectangle()
> rectangle.setXMinimum (pnt.x() - tolerance)
> rectangle.setXMaximum (pnt.x() + tolerance)
> rectangle.setYMinimum (pnt.y() - tolerance)
> rectangle.setYMaximum (pnt.y() + tolerance)
> myLayer.select(rectangle , True)
> in QGIS 1.6 this code works with both shapefiles and postgis layers,
> in QGIS 1.7 it works ONLY in postgis layers, on shapefile layers it
> always returns 0 features.
> Qgis-developer mailing list
