[Qgis-developer] QGIS Mapserver GetMap VERSION parameter
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jun 20 05:11:25 EDT 2011
Hi Pedro
QGIS server is intentionally more tolerant than the standard. Because it
officially supports version 1.3. However, most clients use 1.1.1 or even a
different version. Therefore, QGIS server replies to all versions (with a few
slight changes if 1.1.1). In general, this works well.
With a strict version check, most clients would just see a 'version not
supported' exception.
Regards,
Marco
Am Montag, 20. Juni 2011, 10.36:14 schrieb Pedro Venâncio:
> Hello Andreas,
> For me, as a user, this is even good! However, as the standard states that
> the VERSION parameter is required, I thought this could be a server
> glitch.
> Like you, at first sight, this does not seem a problem to me, quite the
> opposite, but there may be some inconvenience, since it does not conform
> to the standard.
> Best regards,
> Pedro
> ________________________________
> From: Andreas Neumann <a.neumann at carto.net>
> To: qgis-developer at lists.osgeo.org
> Sent: Monday, June 20, 2011 7:37 AM
> Subject: Re: [Qgis-developer] QGIS Mapserver GetMap VERSION parameter
> HI Pedro,
> Are you sure this is really a problem? Any special reasons why QGIS server
> should refuse to deliver GetMap when the version parameter is omitted? Are
> there any interoperability problems with it?
> To me it seems that QGIS server is just more tolerant here - and I
> personally do not care. But there may be reasons that I am unaware of.
> Andreas
> On Sun, 19 Jun 2011 15:39:33 -0700 (PDT), Pedro Venâncio wrote:
> > Hello,
> > I found that there is something that is not well in QGIS mapserver,
> > because in the GetCapabilities response appears the version 1.3.0:
> > However, if you make a GetMap request in the browser, it responds even
> > without the VERSION parameter. This is strange, because this is a
> > required parameter of the GetMap operation, and should launch an
> > exception indicating the missing parameter, but instead the browser
> > returns the map normally.
> > The request I am making is this:
> > http://localhost/cgi-bin/teste_qgismapserver/qgis_mapserv.fcgi?REQUEST=Ge
> > tMap&SERVICE=WMS&LAYERS=perigosidade_rgb&STYLES=default&SRS=EPSG:20790&BB
> > OX=283823,414006,290611,418260&WIDTH=600&HEIGHT=600&FORMAT=image/png&EXCE
> > PTIONS=application/vnd.ogc.se_xml
> > and the answer, regardless of whether or not the VERSION parameter, is
> > the image attached.
> > This is not strange?
> > (I am using Ubuntu 10.04).
> > Best regards,
> > Pedro Venâncio
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
