[Qgis-developer] QGIS v1.7
Duarte Carreira
DCarreira at edia.pt
Mon Jun 20 09:33:25 EDT 2011
I would say you have some other directory in your system path that holds other qt dll's.
In the past I have moved System32 qt dll's to the application's directory, but you have to know which application copied them there in the first place during installation.
Duarte
-----Mensagem original-----
De: uk52rob [mailto:uk52rob at yahoo.co.uk]
Enviada: segunda-feira, 20 de Junho de 2011 12:58
Para: 'Tim Sutton'
Cc: qgis-developer at lists.osgeo.org
Assunto: RE: [Qgis-developer] QGIS v1.7
Hi Tim,
Yes I did indeed, even tried restarting between uninstall of 1.6 and install
of 1.7.
Regards,
Rob
-----Original Message-----
Sent: 20 June 2011 12:46
To: uk52rob
Subject: Re: [Qgis-developer] QGIS v1.7
Hi
Did you try right clicking the installer and doing 'install as
administrator' ?
Regards
Tim
On Mon, Jun 20, 2011 at 1:19 PM, uk52rob <uk52rob at yahoo.co.uk> wrote:
> Hi,
> I have just uninstalled v1.6 copiapo and installed the new v1.7 (win 7
x86).
> However, upon launching 1.7, I get the following error message:
> "Qgis.exe - Entry Point Not Found
> The procedure entry point
> ?append2 at QListData@@QAEPAPAXABU1@@Z could not be located in
> the dynamic link library QtCore4.dll."
> I have tried copying bin\QtCore4.dll to the system32 directory, without
> success. Does anyone have any suggestions?
> Cheers,
> Rob
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
