[Qgis-developer] Integrating OSSIM with QGIS
jr.morreale at enoreth.net
Fri Jun 24 02:41:38 EDT 2011
Hi Mingjie, a quick and easy way to make your code available for
community review would be to create a fork of qgis on github and then
create a branch on this fork.
This way it will be easier for you to keep it in sync with master and
for the devs to have a look and pull your changes.
On Thu, 23 Jun 2011 16:54:23 -0400, Mingjie Su wrote:
> Hi Tim,
> We already installed GIT and checked out the master code. We also
> created a branch on my machine, I am wondering if I need to get
> permission from you to push our branch over to community.
> Thanks,
> Ming
> -----Original Message-----
> From: Mingjie Su
> Sent: Wednesday, June 22, 2011 9:37 AM
> To: 'Tim Sutton'
> Cc: Alexander Bruy; qgis-developer at lists.osgeo.org; 'Peter Borissow';
> qgis-ossim at lists.sourceforge.net; Harsh Govind
> Subject: RE: [Qgis-developer] Integrating OSSIM with QGIS
> Thanks a lot, Tim. I will take a look at Coding document and follow
> the rules.
> Ming
> From: Tim Sutton [mailto:lists at linfiniti.com]
> Sent: Tuesday, June 21, 2011 8:04 PM
> To: Mingjie Su
> Cc: Alexander Bruy; qgis-developer at lists.osgeo.org; Peter Borissow;
> Subject: Re: [Qgis-developer] Integrating OSSIM with QGIS
> On Tue, Jun 21, 2011 at 6:21 PM, Mingjie Su <Su.Ming at geoeye.com>
> wrote:
>> Hi Tim,
>> Attached is our source code. Please let us know your suggestions.
> I received it thanks. I am busy building now. Could I point you to
> the
> CODING document in the top level of master
> https://github.com/qgis/Quantum-GIS/blob/master/CODING
> Section 2.7 explains the 'nice' way to share patches etc. Your
> changes
> are out of date with master and as they are not in a patch, they
> remove various changes that have been made upstream. Basically if you
> follow our guidelines of submitting patches (or creating a fork on
> github), it makes it much easier to evaluate your changes.
> I got some an error when running cmake:
> CMake Error at src/app/CMakeLists.txt:407 (ADD_EXECUTABLE):
> Cannot find source file "qgsnewvectorlayerdialog.cpp". Tried
> extensions .c
> .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp .hxx .in .txx
> I had a quick look at your settings class QgisAppSettings and as Alex
> suggests, it would be much better to use the QgsOptions and / or
> QSettings to manage this (or even QgsProject if you want to store the
> setting per-project).
> I'm going to be travelling the next few days, but I will try to test
> any updated patches you make available.
> Best regards
>> Thanks,
>> Ming
>> Sent: Tuesday, June 21, 2011 4:36 AM
>> To: Alexander Bruy
>> Cc: Mingjie Su; qgis-developer at lists.osgeo.org; Peter Borissow;
>> Hi
>> On Tue, Jun 21, 2011 at 7:58 AM, Alexander Bruy
>> <alexander.bruy at gmail.com> wrote:
>>> Hi,
>>> 2011/6/20 Mingjie Su <Su.Ming at geoeye.com>:
>>>> 1) Since QGIS is hard coded to use the GDAL provider, we added the
>>>> QgisAppSettings class to load the global settings (which is a plain
>>>> text file with key/value pair) to select provider.
>>> maybe I miss something in discussion but is this new
>>> class (QgisAppSettings) is neccessary and why not use
>>> QSettings for this? There is a qgsoptions.h/cpp files to
>>> read and write QGIS setting
>> You are probably correct though its hard to discuss it without
>> seeing
>> the code yet.
>> Regards
>> Tim
>>> Alexander Bruy
>> Tim Sutton - QGIS Project Steering Committee Member (Release
>> Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Manager)
> Skype: timlinux
> Qgis-developer mailing list
