[Qgis-developer] ESA Summer of Code In Space
David Burken dburken at comcast.net
Wed Jun 29 10:07:03 EDT 2011
On 06/29/2011 09:50 AM, Andreas Neumann wrote:
>>> Support of resampling methods for the display of the raster data
>>> (bilinear,cubic,cubicspline,lanczos). Gdal supports these, but QGIS
>>> does not
>>> use them.
>>> QGIS currently only supports nearest, as far as I know, which
>>> results in
>>> very ugly display. It is the main reason I am still also using UMN
>>> mapserver
>>> next to QGIS server.
>>  Ugly? Interpolation of rasters at low resolution looks even more ugly
>> to me. At least the 'nearest' algorithm, showing grid cells as cells,
>> is honest to the data, unlike interpolation algorithms which don't
>> have statistical weight behind them.... Anyway, your mileage may vary
> it really depends on the nature of the raster. color-table based
> rasters or 1bit rasters cannot be resampled of course - but the
> display quality of scanned rgb maps, aerial images or 8bit grayscale
> maps would benefit.
> Andreas
Also satellite data that is being ortho-rectified on the fly will have a
rotation, in which case nearest neighbor is a bad option.  Note Ming's
new ossim provider will be able to do this(ortho) once pushed out.
Dave
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
