[Qgis-developer] Re: python plugin and layer properties window
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Jun 30 04:59:57 EDT 2011
Hi Michael
> What do you exactly mean with composer window class?
> QgsComposerView or QgsComposerView.composerWindow() = QMainWindow?
As the signal would be needed for Plugins, I thought about adding it to
QgsComposerView class. Do you need any additional information coming with the
signal (e.g. which composerview it is)?
> And is it right that the Map Composer is automatically opening after
> calling /self.iface.actionPrintComposer().trigger()/
> so using the composerWindow() isn't necessary?
composerWindow() is useful whenever you need to get a pointer to the window
(trigger() only opens a new one but then you don't have a pointer).
Regards,
Marco
Am Donnerstag, 30. Juni 2011, 10.25:47 schrieb Michael Pfeiffer:
> Hi Marco,
> thx for your answer.
> thx
> Regards
> Michael
> http://osgeo-org.1803224.n2.nabble.com/python-plugin-and-layer-properties-
> window-tp6383931p6532300.html Sent from the qgis-developer mailing list
> archive at Nabble.com.
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
