[Qgis-developer] Shapefile: prj vs qpj (CRS info)
Micha Silver micha at arava.co.il
Tue Mar 1 16:23:00 EST 2011
On 03/01/2011 08:35 PM, John C. Tull wrote:
> Hi Benoit,
> Has a ticket been filed?
> Cheers,
> John
> On Mar 1, 2011, at 9:53 AM, Benoit wrote:
I checked using QGIS 1.6 on Ubuntu, just one shapefile, after renaming
the *.qpj - leaving only the *.prj - and it behaved as expected. i.e.
the correct CRS was recognized without asking any questions. In the
Options->CRS I have global default set to EPSG:4326, and that was not
used, so QGIS found the correct CRS from the *.prj .
>> Hi John,
>> Thanks for your report and confirmation of this behaviour.
>> I'm on windows7 64bits at work and winXP 32bits at home. On both it is OSGeo4W trunk. So it seems it is not OS dependent.
>> Regards,
>> Benoit
>> On 01 Mar 2011, at 18:56, "John C. Tull"<jctull at gmail.com>  wrote:
>>> Hi Benoit,
>>> I can confirm this behavior for me as well. It seems to have crept into trunk in the past month or two. I have been banging my head on this as it is very frustrating. Shapefiles with associated prj, gdal recognizes the CRS, but QGIS seems to ignore it.
>>> Let's look at the OS we are using. I am on OS X with William's frameworks. I build following the OS X build instructions. Any chance you are on the same build environment or is it another OS?
>>> Cheers,
>>> John
>>> On Mar 1, 2011, at 8:41 AM, Benoit wrote:
>>>> Hi Paolo,
>>>> I agree with you.
>>>> Furthermore, the behaviour should depend on the option selected in
>>>> Settings/Options->CRS tab:
>>>> Option: "Prompt for CRS" should ask the user to define the CRS of the
>>>> loaded file if, and only if, it is not defined. Unfortunately if you
>>>> only have a prj file, QGIS asks you to define the CRS. QGIS only
>>>> recognises the qpj file.
>>>> Option: "Project wide default CRS will be used". Here again the prj file
>>>> is not recognised and the shapefile is given the project CRS. It is fine
>>>> when both have the same CRS but lead to wrong location if they don't and
>>>> "on-the-fly" projection has been enabled.
>>>> Option: "Global default CRS displayed below will be used". Again, the
>>>> prj file is not recognised and the shapefile is given the global default
>>>> CRS.
>>>> I have this problem when I want to import a shapefile (in a projected
>>>> CRS) into a project having a Google Mercator CRS and OTF enabled.
>>>> Can this be confirmed by someone, or am I doing something wrong?
>>>> Regards,
>>>> Benoit
>>>> On 01/03/2011 16:57, Paolo Cavallini wrote:
>>>>> Il giorno mar, 01/03/2011 alle 08.26 -0500, benoit-3 at bc-consult.com ha
>>>>> scritto:
>>>>>> Yes, there is a CRS definition difference between prj and qpj.
>>>>>> But, if you only have a prj file you can rename it to qpj. QGIS does
>>>>>> not complain and displays the shapefile at the correct location.
>>>>>> So the way to go forward, at least for me, would be to rename all the
>>>>>> shapefiles *.prj to *.qpj in order to use them in QGIS.
>>>>> This is not the correct behaviour: QGIS should use qpj when present,
>>>>> otherwise prj, if nothing is available it should apply the default, as
>>>>> chosen by the user from the menu Options.
>>>>> If the behaviour you describe is confirmed (in my case it is not), then
>>>>> it's a bug.
>>>>> All the best.
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
