[Qgis-developer] Raster providers
Radim Blazek radim.blazek at gmail.com
Wed Mar 9 03:45:23 EST 2011
Yes, it was explained in one of my previous mails:
On Sat, Mar 5, 2011 at 11:21 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Another issue is, that WMS driver does not automatically switches to
> projection requested by QGIS even if it is supported by WMS server.
> You have to manually select the right projection when layer is added.
> Preferably, the WMS driver should not only to switch to the right
> projection, but also automatically
> select the most similar projection offered by server if no one exactly
> matches. Anybody is aware of an algorithm or ready for use method
> doing that?
> Raster rendering appeared to be infinite entertainment.
On Wed, Mar 9, 2011 at 8:10 AM, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> Hi
> really impressive! What is the behaviour with WMS layer reprojection? It
> seems that QGIS is still doing some reprojection/resampling when OTF
> reprojection is enabled but the server is able to serve the desired
> projection.
> regards
> Stefan
>> -----Ursprüngliche Nachricht-----
>> Von: Ivan Mincik [mailto:ivan.mincik at gista.sk]
>> Gesendet am: Mittwoch, 9. März 2011 07:57
>> An: qgis-developer at lists.osgeo.org
>> Betreff: Re: [Qgis-developer] Raster providers
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> On 03/08/2011 08:17 PM, Radim Blazek wrote:
>> > Merged to trunk.
>> Congratulations,
>> I was testing WMS layer reprojection. It is working flawlessly. I am
>> impressed by speed.
>> Perfect work.
>> Ivan Mincik, Gista s.r.o.
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk13JMMACgkQVqso/9cUsCwJLgCeNCzTpXc92e2IexG/dKb/Fhvg
>> uXgAn1ayCCcax7ONrCXNN+TsaWjCMa9X
>> =+E80
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
