[Qgis-developer] Map tips do not work with reprojection on the fly
Agustin Lobo
alobolistas at gmail.com
Wed Mar 9 04:11:23 EST 2011
I've just found that Map tips do not work (values not displayed) for a
utm layer that is displayed
within a project in another projection (i.e., google Mercator) with
reprojection on the fly activated
(the actual display of the layer is correct).
Map tips works fine for the same layer on its original projection.
Using qgis 1.6 on ubuntu 10.04. Could anybody else also check this problem?
Agus
