[Qgis-developer] Raster on the fly
Ramon Andinach
custard at westnet.com.au
Wed Mar 9 05:10:35 EST 2011
Both.
I can open an existing 1.6 or 1.7 project, or I can work through Luiz's process below.
-ramon.
(Haven't been able to get at r15398 yet)
On 09/03/2011, at 16:49 , Radim Blazek wrote:
> Does it crash if you open an old qgs project or if you start qgis and
> add new layers manualy?
> Radim
> On Wed, Mar 9, 2011 at 2:55 AM, custard <custard at westnet.com.au> wrote:
>> I can confirm this with this data.
>> It is further than I get with my datasets. I usually only get to step 2, and the datum is unimportant.
>> It's quite annoying because it means that any dataset I have with a raster, and "on the fly" selected causes qgis-dev to crash.
>> -ramon.
>> ----- Original Message -----
>> From: "Luiz Motta" <motta.luiz at gmail.com>
>> To: "qgis-dev" <qgis-developer at lists.osgeo.org>
>> Sent: Wednesday, 9 March, 2011 9:26:09 AM GMT +08:00 Beijing / Chongqing / Hong Kong / Urumqi
>> Subject: [Qgis-developer] Raster on the fly
>> Devs,
>> I had problem with image to set "on the fly".
>> The example of image is:
>> http://www.engesat.com.br/cddemo/ikonos/11bits/composicao/psm/geotiff/guaxupe_psm11.zip
>> I am testing with:
>> 1) Windows XP
>> 2) QGIS 1.7 r15395
>> The QGIS crash with steps below:
>> 1) Open image
>> 2) Enable "on the fly" with CRS WG84/Geographic (EPSG 4326)
>> 3) Zoom to layer extent * Crash
>> Regards,
>> Luiz Motta
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
