[Qgis-developer] 1 Mac section was skipped in r15383
John C. Tull
jctull at gmail.com
Wed Mar 9 15:13:35 EST 2011
Ok, so removing lines 13-15 in qgisapp.ui worked. I had to run "make clean" to get it to stick.
Cheers,
John
> Can someone post a diff for this or patch the source. I'm not sure what the line edits are that need to occur.
> Thanks,
> John
> On Mar 8, 2011, at 8:42 AM, Martin Dobias wrote:
>> On Tue, Mar 8, 2011 at 5:29 PM, Tom Elwertowski
>> <telwertowski at comcast.net> wrote:
>>> The following workaround may shed some light on the source of the problem:
>>> Comment out the first line of retranslateUI in ui_ggisapp.h
>>> (MainWindow->setWindowTitle)
>>> This suggests to me that something needed by setWindowTitle for this object
>>> may not be initialized yet.
>> Hmm... would it help to completely remove windowTitle property from
>> main window in qgisapp.ui file?
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
