[Qgis-developer] Bringing diagrams into labeling-ng
Alex Mandel tech_dev at wildintellect.com
Mon Mar 14 23:01:49 EDT 2011
I actually dislike the Annotation layer method that said products use
because it unlinks the data from the labels and leads to one-off
labeling that may break themes. I would propose that with table joins
becoming possible a table join to a write-able table could be an
alternate solution that would continue to use the current system.
Overall +1 on being able to detect/placement amongst all types of map
mark up.
Thanks,
Alex
On 02/15/2011 01:01 PM, Tim Sutton wrote:
> Hi
> As with Juergen, I don't have much insight into the code, but the
> principle sounds great to me and it would be nice to be able to
> interactively place the diagrams as you have done with labels. How
> would the diagram's placement be persisted? In the same way as labels
> using a specified columns? Some users have requested that label
> placement could work like E$RI where the labels can be turned into
> graphics and placement is stored in the project file (or whatever the
> ESRI equivalent of that is) - so that you don't need to have write
> access to the dataset.
> Anyway +1 from me, I look forward to your improvements!
> Regards
> Tim
> On Tue, Feb 15, 2011 at 2:16 PM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Marco,
>> On Tue, 15. Feb 2011 at 10:16:06 +0100, Marco Hugentobler wrote:
>>> Therefore I'm proposing a change to QgsPalLabeling. To make the system more
>>> extensible, it would be good to have QgsPalGeometry as an abstract base class
>>> and derive QgsPalLabelGeometry from it (and diagram specific classes later
>>> too). Each QgsPalGeometry would implement size calculation and drawing in its
>>> specific way.
>>> Any objections or better ideas?
>> Not much insight in that here, but sounds nice to me.  +1
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>> Software Engineer         D-26506 Norden               http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
