[Qgis-developer] Re: Advice on VRP plugin development
cremat0rio
davidsantospinheiro at gmail.com
Fri Mar 18 14:40:45 EDT 2011
Thanks Martin for your help.
Can you, please, explain these words?
> The downside is that you have to build the library for each platform
> separately.
By the way, referring to my second question about the shortest path plugin,
can you advise-me about the best way to obtain this shortest paths between
any two points on a POINT layer, using a LINESTRING road network?
Thanks a lot for your help.
David
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Advice-on-VRP-plugin-development-tp6178156p6185701.html
Sent from the qgis-developer mailing list archive at Nabble.com.
