[Qgis-developer] color table: labels missing?
Benoit
benoit-3 at bc-consult.com
Fri Mar 18 15:02:51 EDT 2011
Paolo,
On 18/03/2011 20:49, Paolo Cavallini wrote:
> Il giorno ven, 18/03/2011 alle 20.04 +0200, Benoit ha scritto:
>> Please check that the attached qml is correct?
>> Also, see picture at [1] showing the effect of the qml on the corine
>> dataset.
>> [1] http://www.bc-consult.com/xchange/Corine.jpg
> Yes, this is what I get: colors are correct, labels are ok, but they
> miss the CORINE code. IMHO, they should be:
> 111 - Urban...
> instead of
> Urban...
> Thanks.
Sorry, I've misunderstood you.
Attached should be the correct qml, finally!
Please note that the 999-NODATA value is set to RGB(0,0,0). This is also
the value of the N/A (or transparent value) for QGIS (as defined in this
qml).
Best regards,
Benoit
Type: application/x-stuffit
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110318/2c7c6aac/GRID_Code.sit
