[Qgis-developer] Compiling Linux/ubuntu 64 bits
Luiz Motta
motta.luiz at gmail.com
Sun Mar 20 14:11:08 EDT 2011
Tim,
I removed qgis directory inside of '/usr/local/share' and
again i made install (sudo make install), at now, i am running QGIS
from my Ubuntu .
Thanks
Luiz
2011/3/19 Tim Sutton <lists at linfiniti.com>:
> Luiz
> Try to remove any existing install of QGIS first - if you have an
> older install of QGIS alongside a development install, it can cause
> such errors.
> Regards
> Tim
> On Fri, Mar 18, 2011 at 9:48 PM, Mayeul Kauffmann
> <mayeul.kauffmann at free.fr> wrote:
>> Hi,
>> I compiled QGIS without problem earlier this week without any problem on
>> the exact same architecture (except the window manager):
>> KUbuntu 10.10 64 bits, Python 2.6.6 (r266:84292, Sep 15 2010, 16:22:56).
>> Could you share the exact sequence of commands you are doing? It might
>> help.
>> Mayeul
>> Le jeudi 17 mars 2011 à 20:25 -0300, Luiz Motta a écrit :
>>> Hi Devs,
>>> At now, i compile the QGIS R15530, Linux/Ubuntu 10.10 64 bits
>>> I can't use plugins python, i receive this error:
>>> Couldn't load PyQGIS.
>>> Python support will be disabled.
>>> Traceback (most recent call last):
>>> File "", line 1, in
>>> ImportError: /usr/local/share/qgis/python/qgis/core.so: undefined
>>> symbol: _ZN14QgsMapRenderer17setDestinationSrsERK28QgsCoordinateReferenceSystem
>>> Python version:
>>> 2.6.6 (r266:84292, Sep 15 2010, 16:41:53)
>>> [GCC 4.4.5]
>>> QGIS version:
>>> 1.7.0-Trunk 'Trunk', 15530
>>> Python path:
>>> ['/usr/local/share/qgis/python', '/home/luiz/.qgis/python',
>>> '/home/luiz/.qgis/python/plugins',
>>> '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.6',
>>> '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
>>> '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
>>> '/usr/local/lib/python2.6/dist-packages',
>>> '/usr/lib/python2.6/dist-packages',
>>> '/usr/lib/python2.6/dist-packages/PIL',
>>> '/usr/lib/python2.6/dist-packages/gst-0.10',
>>> '/usr/lib/pymodules/python2.6',
>>> '/usr/lib/python2.6/dist-packages/gtk-2.0',
>>> '/usr/lib/pymodules/python2.6/gtk-2.0']
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
