[Qgis-developer] fTools Add Geometry error
Carson Farmer
carson.farmer at gmail.com
Mon Mar 21 13:44:39 EDT 2011
Giuseppe,
> I'm pretty sure that, if you unset the "value" property from QtDesigner, it
> doesn't appear
> in the .ui file and then in the generated _ui.py file.
I'm sure you're right... but I am unable to 'unset' the value property in
QtDesigner
> You may also edit the .ui file by hand and remove that line from the xml.
Looks like this is the only workable solution... I'll go with this for now,
though it seems that the first solution should really work...
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110321/ce4768e2/attachment.html
