[Qgis-developer] 1-band raster colour problems
Paolo Cavallini cavallini at faunalia.it
Tue Mar 22 06:12:34 EDT 2011
Il giorno mar, 22/03/2011 alle 06.06 -0400, benoit-3 at bc-consult.com ha
scritto:
> Thank you for reporting this bug. I'm aware of it and should fix it as
>  soon as I find time to do it.
Thanks for this.
> In the meantime, could I ask you to check that a file with the same
>  name as your raster and with extension bccPAL1 exists in the same folder
>  as your raster and then delete it? It should sort out the problem.
Exactly, that did it.
Thanks again.
Paolo Cavallini: http://www.faunalia.it/pc
