[Qgis-developer] Help needed with PyQGIS
Learn Qgis
learn.qgis at gmail.com
Thu Mar 24 05:42:55 EDT 2011
Hi Marco,
thanks for replying... It was able to find SIP and PyQt. But it is not able
to find core.lib, gui.lib from Python/QGIS directory. How do we build these
files? Where is source code to build these files ? These files are available
with default Quantam GIS Installation Setup. I want to build them so that
they are compatible with Python 27. I am not able to find any documentation
about these files.
thanks in advance,
Afzal
On Thu, Mar 24, 2011 at 2:14 PM, Marco Bernasocchi
<marco at bernawebdesign.ch>wrote:
> I had the same issue, try sip 4.10.5 and PyQt 4.7.4 and it should work,
> there are some problems with kde backports versions.
> As well, i'd be nicer to sign your message with a name... ;)
> ciao
> Marco
> On 03/24/2011 06:00 AM, Learn Qgis wrote:
> > Hi All,
> > Is there anybody who can help me out with Python integration in QGIS....
> > ? Please help me... I need to learn to integrate Python in QGIS.
> > thanks in Advance,
> > QGIS Learner
> > On Thu, Mar 17, 2011 at 10:34 PM, Charlie Sharpsteen
> > <chuck at sharpsteen.net <mailto:chuck at sharpsteen.net>> wrote:
> > On Wed, Mar 16, 2011 at 10:20 PM, Learn Qgis <learn.qgis at gmail.com
> > <mailto:learn.qgis at gmail.com>> wrote:
> > Hi,
> > I am new to QGIS. I am trying to build the source code using
> > CMAKE to Visual Studio 2008 environment with python binding.
> > I am using Python 2.7, SIP 4.12.1 and PyQt 4.8.3
> > I am getting below error....
> > *Couldn't load PyQGIS.
> > Python support will be disabled.
> > Traceback (most recent call last):
> > File "", line 1, in
> > ImportError: dynamic module does not define init function
> (initcore)
> > *Python version:
> > 2.7 (r27:82525, Jul 4 2010, 09:01:59) [MSC v.1500 32 bit
> (Intel)]
> > QGIS version:
> > 1.6.0-Copiapo 'Copiapo', exported
> > Python path:
> > ['D:/dev/cpp/build/src/app/**Debug/./python', 'C:/Documents and
> > Settings/Administrator/.qgis/**python', 'C:/Documents and
> > Settings/Administrator/.qgis/**python/plugins',
> > 'D:/dev/cpp/build/src/app/**Debug/./python/plugins',
> > 'E:\\Python27\\Lib\\site-**packages', 'E:\\Python27\\Lib',
> > 'D:\\dev\\cpp\\build\\src\\**app\\Debug',
> > 'C:\\WINDOWS\\system32\\**python27.zip', 'E:\\Python27\\DLLs',
> > 'E:\\Python27\\lib\\plat-win', 'E:\\Python27\\lib\\lib-tk',
> > 'E:\\Python27']*
> > Please help me in resolving this error....
> > thanks in advance...
> > Usually this means that Python could not find the PyQt module or
> > could not load it for some reason. Check your environment
> > variables---specifically PATH and PYTHONPATH.
> > -Charlie
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Marco Bernasocchi
> www.bernawebdesign.ch
> skype: mbernasocchi
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110324/85f3e17e/attachment.html
