[Qgis-developer] typo?
Werner Macho
werner.macho at gmail.com
Fri Mar 25 03:20:30 EDT 2011
Hi!
As it does not affect any function i would not consider it as a "bug"..
It's an annoyance and should have been cleaned out before string freeze
(IMHO).
Of course - if the release manager gives his ok to adjust this strings
to the correct writing i will do it. And surely I'd like to see all
strings correct in the release. (in which file of gdaltools is the
second misspelling?)
But that also means a (of course rather small) string update in all
languages leading to 2 new "untranslated" strings .. Of course they are
already translated but point to the wrong original ..
Tim? Think you are the one to decide that ..
kind regards
Werner
Am 25.03.2011 08:10, schrieb Paolo Cavallini:
> Il giorno ven, 25/03/2011 alle 00.46 +0100, Werner Macho ha scritto:
>> Its in qgsvectorlayerpropertiesbase.ui
>> but we are already in string freeze ..
>> have corrected it here and will commit it as soon as 1.7 is branched ..
>> thanks for reporting it ..
> Wouldn't this be a bug? Wouldn't it be better to fix it before release?
> I also found Slop instead of Solpe in GdalTools.
> All the best.
