[Qgis-developer] Re: Value tool plugin makes QGIS crash
Jürgen E. Fischer
jef at norbit.de
Mon Mar 28 10:17:00 EDT 2011
[cc trimmed]
Hi Radim,
On Mon, 28. Mar 2011 at 15:47:56 +0200, Radim Blazek wrote:
> That would be possible. Do you mean a cache on driver level? Is it a
> cache used in QGIS for rendering somewhere at this moment? Is it
> desired? 1000x800x8 = 64MB / layer, 10 layers ~ 0.6GB. What about
> threads (map composer, globe)?
The layer has a cacheImage(), which the map renderer fills if render caching is
enabled. identify could probably use that - if the data is available in the
raw image at all.
Just a thought. However I wasn't obvious to me however - on a quick look - how
we know the current extent of the cached image. It might be still worth
exploring.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
