[Qgis-developer] Re: QGIS hangs when trying to add stops in color ramp
William Kyngesburye woklist at kyngchaos.com
Thu Mar 31 20:58:21 EDT 2011
It's currently a part of:
http://trac.osgeo.org/qgis/ticket/3497
I've only partially fixed this (a workaround).  There are many color pickers and I didn't want to either workaround them as problems are found, which would create a mix of color pickers, or do all of them, which would be a chore to find, and to revert when it's fixed in Qt or QGIS.
For the color pickers at least, it looks like it is possible for the native picker to work, I just don't know enough to figure out why.  I'm hoping a Mac programmer can figure this out.  But if it comes down to it for release, I'll do the workaround.
On Mar 31, 2011, at 6:20 PM, John C. Tull wrote:
> This is addressed in trunk, although it requires the font and color dialogs to use qt widgets rather than native dialogs. I believe this is a qt bug, ultimately.
> John
> On Mar 31, 2011, at 4:15 PM, jabraham wrote:
>> Cline, Royce L. wrote:
>>> It fails with any color or offset selection. The fact that it hangs
>>> whether I click OK or Cancel in the offset dialog would indicate a problem
>>> exiting this dialog in the GUI.
>> I am having this problem with QGIS 1.6.0 on Mac Snow Leopard 10.6.7.  Has a
>> ticket been opened?
>>> On May 28, 2010, at 9:10 AM, Martin Dobias wrote:
>>> On Sun, May 23, 2010 at 10:50 PM, Cline, Royce L.
>>> <rcline at nd.gov<mailto:rcline at nd.gov>> wrote:
>>> Using the Style Manager, I an trying to create a stop in a gradient color
>>> ramp. With Multiple stops selected, i click the Add stop button and the
>>> color dialog appears where I then select the color and click OK. The
>>> Offset of the stop dialog appears. Whether I click Cancel or OK, QGIS no
>>> longer responds when the dialog closes. At this point I must kill QGIS.
>>> I'm unable to replicate the problem here (linux). Does it happen
>>> always, with any color and any offset?
>>> Martin
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-hangs-when-trying-to-add-stops-in-color-ramp-tp5091804p6228946.html
>> Sent from the qgis-developer mailing list archive at Nabble.com.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
- Marvin
