[Qgis-developer] Attribute data update of a shape file
maaza mekuria
sailmcm at yahoo.com
Mon May 2 20:39:45 EDT 2011
Thank you Jurgen for the valuable information. I would not have been able to get my plugin to do the update I need to have it with out your kindness.
Is there anywhere such items are explained? Is that part of the api doc through inheritance? If so I would try to look into it more and do my homework so that I am not a asking too many questions. But just the same, I am also ashamed to ask, and take your valuable time and I spend quite a bit of my time wandering around.
Thank you Jurgen again and I also say, God bless you.
Maaza
--- On Sat, 4/30/11, Jürgen E. Fischer <jef at norbit.de> wrote:
Subject: Re: [Qgis-developer] Attribute data update of a shape file
To: qgis-developer at lists.osgeo.org
Date: Saturday, April 30, 2011, 3:25 AM
On Fri, 29. Apr 2011 at 07:56:35 -0700, maaza mekuria wrote:
> I have a written a plugin that updates an attribute of a shape file and it
> tells me it ran fine and yet, I am not able to see the changes in the
> attribute table once the program finishes. I am using QGIS 1.6 Copiapo on
> Windows). I am compiling using the 1.7 source, but I have tried using the
> trunk version and it does not seem to matter at all.
Changes to the feature buffer filled by QgsVectorLayer::nextFeature() are not
propagated to the layer.
Use QgsVectorLayer::changeAttributeValue() [1].
Jürgen
[1] http://www.qgis.org/api/classQgsVectorLayer.html#c6713fc84331e0b459f10fd0d7ecd8b8
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110502/dafcd7c9/attachment-0001.html
